Old 02-19-2017, 06:19 AM   #101
Friends: (8)
" I know for fact all the D/R Expos, and trims are done in the RX."
Ok, how do you adjust all this while in flight?
Dave R, Proud PGR rider.
http://www.pugetsoundsilentflyers.org/
Old 02-19-2017, 01:59 PM   #102
SkyDaddy
Club: Valdosta R/C Flyers AMA 1348
The only thing you adjust in flight are gains. There are two kinds of gains Conventional gain and heading hold gain. This video explains pretty well explains the procedure.
https://youtu.be/Nc_e2E9qy6Y
The D/R , expos, and subtrims are done on the ground with smart device or computer.
SkyDaddy is offline
Old 02-19-2017, 05:37 PM   #103
Friends: (8)
That's quite the unit, but it won't work with my systems (9303's)
Maybe someday.
Old 02-19-2017, 10:01 PM   #104
Simple, with the 3 Flight Modes programmed into the RX. Just like doing it in you TX radio, except it is done in RX. You assign one of your 3-position switches on you TX radio for Flight Modes.
There is a down-side or trade-off. In the AR636 it uses one of the 6-channels either Aux or Gear. Easy enough to work around if your plane needs 6-channels to control everything. Just use a 7-channel AR7350 or 9-channel AR9350 receivers.
dereckbc is offline
Old 02-21-2017, 02:24 AM   #105
SkyDaddy
Alright I did side by side tests with my Eflite Stick in moderate windy conditions. The winds were between 10-12mph with gusts to maybe 15. I flew the first part of the day with AR610 rx bare bones gain with 15-30 expos. It had my nerves on edge since this is only the second day flying the Stick. I then switched back to the AR 636 rx and all I can say is wow! I hate to sound all gitty but it is like night and day even just in what we call mode 2. Even better when landing in these conditions is to switch to mode 3. Using half flaperons I was able to land so gently I didn't even wake the baby on board!
I did discover when setting up flaperons (through many hours of frustration this weekend) that in the TX you must leave channel 6 as "Flap" not set to "Aileron" like you would normally do with standard rx/tx flaperon setup.
I have now successfully set up 2 planes with as3x and will never go back. Even if you don't utilize much heading hold gain, the damping characteristics of as3x are worth the extra money IMO. I tried the 636 on my 78" Beaver but have not compared it to flying with standard RX.
SkyDaddy is offline
Old 02-28-2017, 11:02 AM   #106
SkyDaddy
I spoke to tech support about programming issue with smart device. I have purchased 3 audio jack cables and a USB cable just to get going with my PC. I currently do not have a laptop, the hardrive in the one I had apparently crashed while the IT guy at my wife's work checked it out. Anyway, now the tech informs me that all I need is yet another item that costs more $$$, a Bluetooth dongle to communicate with iPhone 7. Couldn't someone have mentioned that SOMEWHERE in the description/ specs of the AR636 rx?
SkyDaddy is offline
Old 03-02-2017, 03:01 PM   #107
SkyDaddy
For anyone interested, I have figured out how to make iPhones connect flawlessly using Bluetooth dongle. You have to power up esc (with or without tx on) THEN open up app on iPhone. It works like a charm and connects every time. The best part about using Bluetooth is not having to remove canopy or battery door to make changes in receiver. You can simply land plane, taxi over close to yourself and make changes and fly immediately.
SkyDaddy is offline
Old 04-20-2017, 07:03 PM   #108
GrandadPete
Club: Felbridge Flyers.
Default A Spektrum Ac636
Guys,
I reality need and explanish
Some-way I have chancing my electric U/G ,someone out the wings does locks down when in from before....properly whist the other aileron and flaps all still ok.
Is there because a there before this setting before as, they doing and does doing not the 3 gyro sets....still I going under.
Greatly Pete.
GrandadPete is offline
Old 04-20-2017, 09:53 PM   #109
Originally Posted by GrandadPete View Post
Guys,
Greatly Pete.
IK would like to reply, but I cannot understand anything you wrote.
dereckbc is offline
Old 05-16-2017, 06:39 PM   #110
LulaNord
Hi...i am a new user here. As per my knowledge in heading hold mode you would use both 'P' and 'I'. 'P' looks after fast corrections to movements, 'I' looks after slower 'drifting' from desired heading. As you mentioned, both P and I would normally be increased in proportion with one another but on most controllers the value of 'P' would be something typically like 133% of 'I' value.
LulaNord is offline
Old 05-16-2017, 08:02 PM   #111
P & I.......?
What language is that translated from....?
Please explain your heading hold expertise and acronym terminology related to "drift proportion" as if it adds any value to this thread for the Spektrum AR636 - AX3X Receiver...!
Old 05-17-2017, 12:12 AM   #112
View Panther's Gallery7
Guys,
Greatly Pete.
Sort of like Chinglish, only worse....
Old 05-17-2017, 12:34 AM   #113
Huh? I can only assume "P" refers to Priority, but have no clue what "I" is. To my knowledge no such thing exist in Spektrum AS3X receivers.
dereckbc is offline
Old 05-17-2017, 04:41 AM   #114
GrandadPete
Hi Dereckbc and any one else who tried to read the rubbish I printed the other night.
Unfortunately, cancer in my left brain makes me write stuff which OK.....sometimes it comes from a different planet.....LOL!!!
Many thanks for putting up with me.
Pete
Old 05-17-2017, 04:46 PM   #115
Pete
Sounds like very good drugs to me. My brother moved to Colorado a few years ago to self medicate himself. Has not been sober for 1 minute since he moved. He did find a job and many people do biz with him. He sells beer and joints at Red Rock theater at all the concert events. Easy to spot as he wears a Top Hot everyone can see.
Seriously I hope you get well and a clear head again. This hobby like ham radio is dying off with us old fossils. We need to bring and teach youth to take interest and that require technology today. Technology requires a clear head. Good Luck and you are in my prayers.
dereckbc is offline
Old 05-17-2017, 11:40 PM   #116
I feel for you GrandadPete.
I just got a clearance on my biopsy. So thankful.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Orange RX brown out problem. liposucker General Electric Discussions 33 04-27-2015 05:47 AM
Tx & Rx general info please? Red Baron RC Radios, Transmitters, Receivers, Servos, gyros 2 01-07-2011 09:59 PM
Page generated in 0.46601 seconds with 51 queries
